What do i need to do to it to pull about 400 hp. It sits currently at 250 hp. What engine mods, and brand suggestions that i can start looking at... Also would it be better to switch to an auto trany. Since i have the 465.
my suggestion would be to start saving your money, none of this stuff is cheap.... start accumulating some parts, and during that time, read this forum over and over... so you can learn what needs to be done and the best approach... honestly, it doesn't sound like you have much experience and knowledge will be your best mod...
you have ALOT of things to consider.... to start, h.p isn't a be-all... trucks live on torque, so that is a HUGE deciding factor in what parts combination you run in a motor.... it applies to everything from head/cam selection to exhaust primary sizing, etc, etc...
it isn't just a matter of throwing high performance parts at a motor... what's the motors mileage? it's real easy to throw a new top end at a motor, heads/cam/intake, then nuke your bottom end... a compression test and close visual inspection once the heads are off may reveal cylinders not worthy of fresh valve seats, etc...
the absolute first thing to consider is exhaust..... it's the first thing a mill needs to be woken up... and no matter what you find in the motor, it's a transferable part...
a manual to auto is easier than auto to manual, but you still have some things to consider.. you'll need a new radiator for trans cooling lines... a shifter..... different x-member... and modded or new driveshafts...
as you can see, there are tons of things to constempate.. not to deter you, just want you to be forewarned... reading and asking questions in here will be your best friend...
