R3MiX
Registered Member
So, I've spent a short while here asking questions, and lurking around reading posts. Now I figure its time to show you guys the heap I'm working with.
The specs I've got are as follows:
1979 K5 4WD
350 SBC under the hood, to a TH350, X-fer case is unknown to me, no idea how to tell.
40" boggers (which I hope to replace with some 35"s when I have the money.
No A/C. I (halfway) set up the old compressor as an air compressor. works well. 65ish lbs of pressure comin out of it.
only half the original gauges work (tach and speedo dont)
And now for the pics...
This last one is of my 5 gallon air tank, I hook the compressor up to it so I have some kind of storage for putting air in tires.
1979 K5 4WD
