my 89 without 1/4 or floor! making progress!
bablazer73
Starr South Carolina
progress pic, finally got rear floor and the drivers 1/4 off. Now I can install all new ploy body mounts and 1" body lift.
It unbolts at the rear, where it attaches to the floor, then unbolts from the wheelwells. I used a spot weld drill and drilled the spot welds inside the door jamb and the inside the pillar, and then drilled the 4 spots where it's welded the top section. Then it just about pulled off. It wasn't hard at all. Trying to remove the rusty, crusty floor bolts, all 4 of them took longer than anything!!
You Killed my truck! /forums/images/graemlins/hack.gif
Lookin good! I thought u nearly had it back togather tho.
just remember no hockey pucks this time /forums/images/graemlins/whistling.gif
holy crap!!! /forums/images/graemlins/hack.gif
and i thought that truck looked rough when it was sitting on the side of the road in newburg /forums/images/graemlins/histerical.gif
im glad you bought that truck otherwise i would have got stuck helping andre do that
Your almost narrowed. Just start pulling and cutting and you'll be there.
