thedrip
I've thrown in the odd little post about my buildup as I went along, but now I've put together a beginning (of this build cycle) to current build thread. Lots of pictures, feel free to let me know what a hack I am.
What it looked like before I tore it down. Significant body damage, enough that I couldn't get a safety inspection in Hawaii. 3/4 ton axles, 31's.
Blazer torn down to a rolling chassis. I achieved this great step with the help of my backhoe. Proper equipment sure makes life easy.
This little guy wandered out of the woods behind my house every so often during the build to eat the grass in my driveway.
I then pushed the blazer rolling chassis aside, and spent one of my best birthdays every stripping down my m1028 donor truck to end up with various bits.
I then rolled the blazer chassis back into the shop, to begin preparing it for the build. I didn't do things quite in the wisest order, as I kept getting these brilliant ideas to change the build as I went along. This is the front spring hanger relocation to allow me to use 56" long springs up front, effectively moving my axle forward about 3".
Mocking up the position for the rear spring hangers. I used the 2 sets of front ahngers from CUCV trucks to get 1ton spring spacing. I moved the front hanger forward 4" to allow the 56" springs to run long side forward (opposite of stock)
With the rear hanger positions finalized and drilled, I unbolted everything I could fromt the frame and blasted it with semi gloss black. I wasn't really worried about getting a great finish, the truck is all about performance not looks, but when you take a vehicle down to a bare frame, you feel the need to paint parts.
At the same time I disassembled all 4 leaf packs and sprayed each leaf the same semi gloss black
