shaun89
Hey guys.. i am posting here on my bro's name.. (thanks shaun). I have a stock 88 350 in my truck. I recently got a hold of a 4bolt 350. It was a carbed motor. The numbers so far off of it are pointing at a 69-72 block i believe and just some 1.94heads. It was a remanufactured motor (has the aluminum tag) but i would like to build it up. It needs new cam bearings so some machining is needed. I am going to strip it down to block and send it out.
My question is should i leave the stock piston size? and put the money into heads? Or bore it .30 over and get ok heads? My goals are about 300hp and roughly same for torque all on TBI. So far i know i need to bump up the injector pressure and get the chip burned. I have NO clue what a good/cheap set of heads are tho. I am more concerened with having a motor that is very reliable, strong DD, but still can put down a bit of power over stock 100hp im getting now
I have been reading on thirdgen.org and there is just sooo much info its overwhelming. I would like to go w/ the best torque cam i can for stock tbi. I guess my main concern is not having to do a TON of custom tuning, i'd like to basically tell tbichips.com what my specs are and have them ship me a chip if that was needed. Sorry that all of this seems sooo scatter brained i am taking in a lot of info on this stuff!
Sooo what cam/head/intake combo would you guys best recommend for a stock tbi other than injectors/chip to get some decent power? thanks
. I have been reading on thirdgen.org and there is just sooo much info its overwhelming. I would like to go w/ the best torque cam i can for stock tbi. I guess my main concern is not having to do a TON of custom tuning, i'd like to basically tell tbichips.com what my specs are and have them ship me a chip if that was needed. Sorry that all of this seems sooo scatter brained i am taking in a lot of info on this stuff!
