My Custom one-off factory Gauges (UPDATED! Added Elec. Skematic)
Those white face gauges look preety sharp! How about using a cluster from a 80s Camaro?
I wanted something that was plug and play!!!! This harness plugs into this cluster and there are not modifications required
FYI, if you happen to get the same Gauge Pod, here's out it pins out:
Note, these are not OEM colors, my harness I built myself.
The Hi-Beam is mislabeled too, the 'other' wire goes to Off-Road light switch (to slave the off road lights on the hi-beam switch), not to the 'light switch' as labeled.
Crap, I just realized, that Skematic is missing the Tach wiring, it has seperate inputs. I'll add that in a bit. Sorry. It's simple though, +,- and feed from distributor.
