My doors are shipping today!
CherryK5
Austin Texas
Sorry. Just a little excited and felt like taking my share of bandwidth. =]
Been waiting... i dunno. 6 weeks. But Kert is the man (duh) and got them doneeee. Im super stoked!
Actually he's supposed to send me some!
I dunno when that will be or if he remembered.
That's something he requested.
6 weeks is a bit off the norm but that's about what we're predicting now. Just can't move fast enough to get it all done.
I stopped working every sunday too. I hope you guys don't mind too much. I don't want to get burnt out.
Yup. Its my need to be different. Had to make it mine. Well... I had to make Kert make it mine. :D They will get white.think line or line x once I get them.
And thanks again Kert. Sorry for that pain in the arse set of angles.
I welded those tubes in my door too when I got mine. I like the extra protection. Don't want a huge rock jetting through a big opening in the door.
Once installed, do you know if the rear end of the door is flush with the body or recessed? Just curious if the door jamb would stick out and catch trees, rocks, etc.
It's supposed to be pretty flush. The pin is also adjustable in that regard and more so then a stock door since the door seal is no longer in play.
i dont mind kirt. you need a life :whistle:
and we dont need you burnt out and gone
Thanks bud! Appreciate that.
angles in the center are actually a piece of cake. The one at the rear is just into the bend. Small enough you think you can cheat it with a straight notch but just enough to make that not quite work. Neither are bad to do, just getting them lined up straight with each other. Measure alot and swear it looks crooked as hell by the eye. But the numbers say its right. But....:doah::D
Got them rattle caned and installed. line x will come soon though. this is just to keep the rust off.
Damm, They match your cage perfect. I would through a white stripe over the red somewhere and call it good. They look good white! Whatever you do, They are sweet!:waytogo:
Looks awesome! Snap a pic from inside showing the "wahoo handle."
