blowedupmotor87
I've read a bunch of threads about longer leaves moving the rear axles back and the front axles forwards but, I haven't seen these two questions answered:
Does the steering box (assuming crossover in place) need to be relocated with a B52 kit?
How the heck does the rear diff (when running a 14BFF) not hit the fuel tank when running longer rear springs?
Then, a question that wouldn't be answered in a swap thread since the swap is going in at the time of the thread:
If I am running 3" of lift now, and am planning to go 1tons, is there anything I can do (that'll work fine with my current 3" lift)to make it easier to do a long spring swap later (should I ever decide to)? I plan on running shafts with long enough slip joints that they won't be a problem, any other considerations? Thanks!
