blackk5350
i was just wondering what color the stock tbi engines were for 1987. mine is a light blue color. If it is not a astock engine what do you think it came out of. it is a 1987 350 th400r
ok ill do it tommorw its dark out here in kentucky right now so ill do it when i get off work tommorowCrawl up on there and get the number off of the block, it's on the left side of the bellhousing behind the head. Then search it at www.mortec.com
The newer design Chevy , I have no idea what color they are , I can't afford an LS motor , so I don't really care![]()
oh, and I picked mine up for $275.![]()
You can also get carb manifolds for them now.![]()
"Jasper" rebuilt engines are usually light blue. A lighter blue than GM blue from late 70's early 80's. Im not even sure if jasper is still in business but they were a popular replacment engine for a long time. A few places around here used to have $1199 specials, you got a jasper long block and install.
I still say its some sort of reman. An 87 should have a black engine from the factory.I was a car guy first , I still read the mags . You can unbolt 5.3 from a truck , add a kit for 750 dp carb , and make 343 hp right out the box . New heads over 400 hp . Cam on top of that and over 450 hp .
