Chip Cross
Registered Member
Well I am going to pick up my first K5 tomorrow down in south Florida today. I am going to use the thread to show my build progress. This thing is a sleeper and what I mean by that is thing built up very well are ready.
It has a 454, Dana 60 front 14 bolt rear, F/R lockers, 4:56 gears, Th400 trans and a Np 205 transfer case. But is look like a plain old 1976 Jimmy on 35 from the side. Every sine I was a child the paint scheme on this Jimmy is my favorite GM paint scheme. My other favorite paint scheme is the mint green and dark metallic which was on my 1976 High Sierra man I miss that thing but anyway moving on.
Info from the previous owner....
Hedman ceramic coated headers w/ 2-1/2" dual exhaust to rear w/ turbo mufflers.( FACTORY DUAL EXHAUST TRUCK, SO NEVER ANY EMISSIONS!) 1986 military CUCV diesel TH-400 transmission and convertor, B & M Trans-Pak shift kit, adjustable modulator, factory GM deep sump pan w/drain plug. 1986 NP 205 gear driven transfer case w/ bolt on yokes, skid plate and new GM one piece mount. 1986 military CUCV Dana 60 front end w/ 4:56 gears, Lock-Rite locker, welded 1/4" heavy duty steel cover, new brakes, kingpins, springs, bushings, bearings, races, seals, tie-rods, adjusting sleeves, dropped pitman arm & drag links. 1986 military CUCV 14 bolt full floating rear-end w/ 4:56 gears, Detroit locker, welded 1/4" heavy duty steel cover, yoke guard, new axle bearings, races, seals, rear disc brake conversion with all new parts. New custom made rear driveshaft and u-joints. 4" BDS suspension lift kit with new military wrapped springs, polygraphite bushings and matching shocks. ESP polyurethane extended bump stops. Off-Road Design greasable polygraphite bushings, front and rear heavy duty shackles, steering box brace, rear u-bolt reversal kit, extended stainless steel brake lines, and sway bar disconnect kit. Military only front frame braces by firewall and motor mount. Extra cross-member added to frame for rigidity. B & M external oil cooler, transmission cooler, and power steering cooler. Rear disc brake conversion consists of: 1986 military CUCV hydro boost with a new pump, CNC machined brackets (no spacers), '78 Ford 3/4 ton 4x4 front rotors, '76 Chevy 3/4 ton 4x4 front calipers, '79 Pontiac Trans-Am WS-6 proportioning valve and hard lines, '91 Chevy motor-home (P30) master cylinder. Ford 16" x 7" steel wheels w/ original GMC stainless steel hubcaps( fronts are custom cut to clear the locking hubs). Dual Unity cop car spotlights, dual batteries with 1/0 welding cables. 4xArmor(?) rear bumper w/ 8" drop hitch. Military CUCV brush guard with KC lights, along with military front and rear clevises. 31 gallon fuel tank w/ factory skid plate. All new door hinges, hood hinges and springs. Bench seat ( has stiching coming undone), tight tilt steering column, new dash pad with all Auto-Meter sport comp gauges including tach, speedo, oil pressure (with stainless steel braided line), oil temp, transmission temp, water temp, volts, and fuel level. LED lights for turn signals and high beams. Line-X' d from firewall to tailgate ( no carpet), custom diamond plate aluminum storage box mounted behind seat, custom Craftsman toolbox mounted in rear. Factory aluminum radiator and new heater core. 315/75/16 (35's) Wild Country radial RVT mudders have less than 1000 mi on them. Military running gear had 28k miles when I purchased the complete running vehicle in 2006. Vector 3000 watt power inverter with 1/0 welding cables is mounted under the seat and will run most household appliances.
I know both rocker panels need replacing which is no biggie, but other then that the tub is a rust free Arizona truck. I have a fresh 454 from my K30 or I could sale the K30 and put a 5.3 Chevy in it, I am not 100% at this time. My K30 is built up so I hate to tare into it and rob parts. I am going to the ORD crossover high steer for sure and put my new Warn 8274 50 on the front of this truck.
