MY goals, what are yours?
milspecjimmy
raymond, maine
by the end of summer i hope to do the following to my K-5:
1) ORD zero rates
2) Atron Rear disc conversion
3) locker in the rear
4) 38" TSL's
5) full smitty built cage
6) open up the front fenders
7) make hard top into a slant back like a military hard top hummer
8) repaint
9) winch
not all in this order, but all along the way. then when this is done i want to get a 73-75 and start all over /forums/images/graemlins/thumb.gif
2 more inches of lift. This will happen in March, complete with anti-swaybar dissconnects (thanks Kumma /forums/images/graemlins/thumb.gif)and shackle flip (BDS suppling the lift of course. BWT will be selling my 2.5 BDS lift)
35 inch swampers. (I liked my truxus 33's so maybe)
Rear bumper/tire carrier
And if this is dreamworld a 383 with TBI.
- Hydraulic steering
- Roll cage
- Battery relocation
- Maybe some fiberglss.
We'll see what else. /forums/images/graemlins/grin.gif
3 inch body lift
6 inch suspension lift
and MAYBE 39.5 inch TSLs, they might have to wait until fall/winter though. /forums/images/graemlins/crazy.gif
ARB
42 TSLs /forums/images/graemlins/truck.gif /forums/images/graemlins/thumb.gif
Hmmm lets see-
1) 5.13 R&P front and rear
2) Shock towers front and rear
3) Atron wrap bar in rear
And about 1000 more things if I hit the Lotto /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/grin.gif
Eric /forums/images/graemlins/usaflag.gif /forums/images/graemlins/k5.gif
1) Long Travel Leaf Springs from Deaver
2) 2.5" Sway A Ways in the front, and maybe 3" Sway A ways in the back
3) Maybe Some fiberglass
4) On board air
5) Get new seats and finish interior
Find a job! Oh, you ment for my truck. Well, as soon as I find a job I'll make more plans. /forums/images/graemlins/crazy.gif
Your # 7 sounds intresting, do you mean out of glass? The only Blazers I've seen fastbacked (I just made a word /forums/images/graemlins/grin.gif) were done w/ a soft top.
I still need a winch, roll cage, fule injection, and a diffrent bodie /forums/images/graemlins/crewcab.gif
New lift to clear 44's with some trimming
gears and lockers
finish big block rebuild
get the doubler kit
roll cage installed
put all the interior back together
install stereo system
hook up all electonics(lights cb, scanner and so on
winch
this could go on forever....
Short term......(as in the next few weeks)
1 Get tranny rebuilt AGAIN!
2 fix rear hub bearing leak
3 weld rear, MAYBE front
4 fab a snorkle
Short long term.....(maybe this yr)
1 cage
2 swap in 205 Tcase
LOONG term....(next yr or 2)
1 D60 front (or go Rockwells /forums/images/graemlins/thumb.gif)
2 few more inches
3 44 Boggers
New parts for crossover steer. Front driveshaft with longer travel . Rear shaft with 1350 joints . 2in front springs{will make lift 8in}. 203 doubler setup.. Front locker,OX or ARB. HS9500i winch . Nice sterio to drown out TSLs sometimes . Be happy to get first three... Fantasy--Get on cover of 4X4 Offroad{might as well wish big} /forums/images/graemlins/crazy.gif /forums/images/graemlins/truck.gifer on 38s in TENN.
first is the D60 rebuild.
next is some 6 inch springs up front.
then the BIG stuff starts.
roll cage, FULL.
fuel system, fuelcell and pump.
TBI conversion. need a manafold and Vortec heads
windshield.
guages.
doubler
42 or so tires.
rims for above tires
cutting brakes
t-case e-brake
line lock
put the engine back together, cam and above TBI
install it all.
then figure out how to get it out of the garage.
oh, figure out how to make a few parts i have gotten from members fit right.... some i knew needed mods before i got them, most "should olt right in"
yeah, i wish.
my list is actualy longer than this, by a lot, but its not to be done all by summer. i dont have that kind of cash.
Grant
1. 14bff with discs and 4.56's, d44 up front with 4.56's.
2. 454 built mildly.
3. 6 inch front springs.
4. shackle flip with 57 inch springs. zero rates if needed.
5. at least 35 inch tires.
6. cut all top off and make a soft-top.
not all in the same order just lil by lil. i need a job tho and i need to get my business going good.
jacob
1.convert 14bff with atron setup (eldo calipers)
2.install the six inch springs up front
3.springer flip
4.full cage
5.beard seats
6.diamond plate lower 6" all the way around
7.convert front to 8 lug
1)frame painted
2)get d60/14ff
3)driveshafts
4)fix body
5)paint
6)put back together
7)wheel before 4th july
My truck is down to just the frame and need to get it done
Thought I'd get trashed for 4X4 cover thing.Got pic in there for 91 Smokey Mtn. Trek.Won't see truck beat up like mine on cover on anything. /forums/images/graemlins/crazy.gif /forums/images/graemlins/truck.gifer on 38s in TENN. /forums/images/graemlins/thumb.gif
1. Build new motor: 402 BBC
2. Detroit locker in rear, something? in front
3. 36" Super Swamper TSL radials
Hopefully done by early summer, so I can wheel with some fellow CK5'ers I've met here in the arctic Ohio. /forums/images/graemlins/grin.gif
