My Holloween Trailer Turned into a project_____pics.
chevysmithz71
Kingsburg, Ca
First it started out just stripping some paint off the sides. It was Black, yellow and orange.
NOW THIS>>>>
Looks even better than the last time I was there.... did you rattle can it or go the sprayer route?
No rattle can here. 1 gallon and a quart later of Rust-oleum flat black. All new LEDs are going around with some new round 6 wire to light em up. The things hanging are the ramps I added that get tucked away nicely underneath. That means I added some 3/4 rod at the back to hook them on.
When I picked up that dually the front was on and the tilt wanted to go down. So, if I had those ramps on ready to go it could lay flat and the ramps would come into affect. The whole trailer got a lift as well. It has a way to raise and lower the tilt mounts at the axle by 4"s. So it could have been a complete deck over before I built those wheel wells.Oh well.more pics later.
I redid the tongue because of the god awful hunk of steel that had been tossed on. Added weight distribution brackets and sway bar kit.And some Hooks. It seems we always needed something to yank from.
Oooo fancy.... good idea with the hooks. I was thinking about how I was going to load the k10 on if I broke at pismo last time. Luckily I didn't have to find out. ;)
