My dad and I spent some time this afternoon bench bleeding my hydro clutch. I rigged up a couple pieces of wood to mount the slave to so that I could block the slave piston in the contracted position as per instructions from 4x4HIGH.
We bled the system really well. At one point I tested it by having the bleeder valve closed, and pushed on the pedal by hand. I had a nice firm resistance that I couldn't compress. I decided to bleed it one more time for good measure. After that, for whatever reason, I had tons of air in the system and no matter how much I bled I kept pushing out lots of bubbles.
Shouldn't have screwed with it.
So, I'm thinking I have a tiny leak in the system. My slave cylinder is pretty nasty - has a bit of rust inside the bleeder valve space. Perhaps I should start by replacing the slave and the hydraulic line which has a couple cracks in the rubber. What say you? The master is nice and clean, though I get quite a bit of movement out of the plastic coupling that goes from the reservoir to the master itself.
What say you?
What say you?
