It's not that she won't idle, but it is either too high or two low.
1979 k20 very stock 350 and lots of vacuum lines. No vacuum leaks that I can see. Reset the idle mixture screws at about 3 turns out each. Idle speed screw is just barely touching. This gives me the best quality idle, but it's about 1k rpm and when I shift from park to reverse or drive I get the big clunk.
When I turn the screws in about half a turn each, I get 6-700rpm, not as smooth an idle but no driveline clunk. It also does not want to start in the morning set this low.
I'm looking for a balance between the two. Also how much of this emissions crap can I throw away? All of it is hooked up.
