They are ?? heads at the moment.what rpm range do you plan on most of your usage being in?
rocks, mud, sand, roads?
what kind of heads you got there, and what mods do they have?
They are camelback heads.
Rocks are the main thing. So, a low RPM.
That's true...unless you have a cradle for it stand it up somewhere it won't get knocked over...Pictures already taken , now stand that crank up if you can , its better to stand them up so they don't bend .
I likey the bottom end so far . Should be sturdy enough for a long life if its only rockcrawling . Those rockers are beef too . You need guideplates and screw in studs now , because the will to spin it will come over you once in awhile I'm sure![]()
Guess so..I always used a piece of cardboard on the concrete floor to make a little cushion.Should stand the heads on end as well.
Martin
Think it'll be a couple more days.
I'm not assembling it myself though. I know how but just don't feel like it. Plus these guys know more than i do.
camel backs didnt have accesory holes.the cars they were used on had no power steering and the alternator was hung off a mount that tied into the header.you can still buy it at auto zone.i ran theese heads on a well built 408 one timestill no accessory holes,hmmmmm? *scratching head
