I bought a new GM Goodwrench crate engine for my 1991 V3500 (pn# 12568758). It is a 2-bolt main with 9.25:1 compression. This is the last of the TBI direct replacement engines that GM offers. All others have been discontinued.
I installed a COMP Computer Control 12-304-4 cam into it (205 Dur @ .50 / lift .406 / LSA 111.4). This is a mild cam, but it will increase duration by 40 degrees and lift by .20 thousands over the stock cam. I also had the stock TBI manifold bored out to 1.835 thousands of an inch to match the bored out TBI, which I bought from RV Morse.
I did some smaller mods to the engine as well like 5-qt oil pan, oil pump pick-up retaing bracket, and steel sleeved intermediate oil pump shaft. I am also doing some work to the 4L80E trans in this truck. I am replacing the torque converter, internal wiring harness, solonoids, and VSS sensors.
I will probobly start a biuld thread on this in the future with pics.
