My new project truck Pics
slimlynn1
Hamden, CT
Check out my new project truck.
It is going to be a class 3 NMRO mud racing truck. I am going with 39 1/2 Boggers in the rear and some small tires probably 35s in the front. It has a full cage with front frame rails and a 3 link coil sprung FRD 9" rear with a spool. I need to put in a front axle, probably a 10 bolt or Dana 44 that will be coil sprung with ladder bar type suspension. This will be powered by my current engine from my K5 Blazer. For a transmission I will use a TH400 and will use a chain drive instead of a transfer case. Hopefully this will only weigh about 2800 lbs. with me in it.
