My new truck: Diesel k30!
muddybuddy
1 ton status
Northern, VA
well after looking for a long time, i finally found a diesel for a reasonable price. it is an '85 k30 6.2/400/205 60/14b combo with 4.10s and a trac-lock (gm gov lock?), (guy just completely rebuilt axles) it has a 1410 yoke off of an '05 3500, and has the 3500 driveshaft shortened to fit. the truck has 145k miles, has 8" susp lift and 3" body lift, with 39.5 boggers (worn) on 16.5x12 eagle alloys (MT classic copies). its got 2.5" straight pipes out near the stock location on both sides (90*), and the sob is LOUD to say the least. im going to put mufflers on it because it gives me a headache on the highway (along with the damn boggers:doah: ), but for now its going to have to stay as is. The truck needs a little TLC (needs rear main seal, and new driverside floorboard and rockerpanel/cab corner welded in, which i have already). it also has a 1/2" plate on the frame under the bed from where a 5th wheel used to be set up.
the guy i bought it from didnt seem to know alot, he said that slipyoke was the way to go (idiot!) and swapped a slipyoke onto the 205:mad:. he also disconnected the vaccum line for the th400, and said that it wasnt necessary and that it shifted better because it would rev higher before shifting without it:eek1: . i reattached the vaccum line and it shifts much better now.
anyways, this truck is going to be built up for dd/trail warrior. i plans are to remove the 8" springs/blocks, install some slightly lifted 52's up front, shackle flip, 1" lift spring perches, 1" zero-rate, 1" body lift for around 7" lift total. im also going to change tranny's and t-cases, install a gm8 turbo setup, lockers and eventually chromoly shafts, h1's and 42 iroks. ive got most of the parts, and i supose ill make a build thread like everybody else :haha: :doah: in the not so distant future once i start turning wrenches.
on to pics, let me know what you guys think.
Haha,
Man the parents must love you! Lookin' good James. Just don't go out and pull out any stuck furds, if ya know what I mean! At least you have a 1 ton frame now! :wink1:
Dual tanks! Cool!
Man, you're gonna change that bad boy all the way around, huh? Guess you have to with the strict VA lift laws. Can't wait to see what you do with her.
Best wishes!
Manny
its got stock style steering (drop pitman arm, drop draglink, steering block) its going to get cross-over and hydro-assist.
manny, the boggers are 39.5x18 on 16.5x12 eagle alloys. they are pretty dead in the center (over inflated) but they sides have huge lugs. as i mentioned i already have the new rocker panel and floorboard and cab corners, just need to get my buddy to weld them in
Muddy,
That's some scarey stuff with that lift block. Scarey stuff.
Manny
MuddinManny said:
Muddy,
Manny
Yeah, R-O-N-G-E- wrong :haha:
I s'pose it's got a dimple cast in it to stick into the axle, but the way it sits in the U-bolts it's just begging to go POP out at the most inopportune moment :eek1:
That said, not a bad truck.
-- A
Looks like you have your work "cut" out for you. I will be watching this intently. I hope you'll post up pics of progress and of the body repaires. I have a small section of floor-board coming up to do and I'd like a little knowledge before I go cuttin'. Looks good Mr. James. We won't recognize her when you're done!
Manny
looks like a nice start muddy! Why not replace the rockers with rectangular tube?
badass man. good find. what did you pay???
all you gotta do is deflate the tires and run em on the outer edges now...haha...j/k
good find, can't wait to see the build thread.
i paid $3k for it. considering its got some parts on it i plan to sell, it seemed like a fair price considering the other i had looked into were more money and i would have to drive several hours (time and gas money), this truck was 30min away.
i completely agree on the steering and the lift block, ive never had a vehicle that had blocks in the rear. the block almost looks like its 2 welded together SCARY! its not going to be on the road much until the shackle flip and other springs and steering are on it.
ive got most of the parts already, its mostly just a matter of time (being in school fulltime). most work probably wont get done til i get out of school in the beginning of may, and that will allow me some time to rebuild the tranny im going to drop in :)
KGsK5 said:
Good find man. What tranny/t case are you going to be running?
its going to be 4L80E/WMS 3.2:1 203/205 triple stick doubler. ill be selling the 400/205 in may once i get that setup in the truck:D
thanks guys, yea it runs really strong. the motor was my main concern, because im basically changing everything else :) if that motor dies, a 6.5 will replace it ;)
You're right, the PO doesn't know much. Strait piping a diesel is indeed very popular and makes them sound great, but diesels with a TURBO!!! Otherwise it's just stupid loud and annoying!:haha:
Looks good man.
looks like a real mad max warrior machine!! I cant wait to wheel alongside it!!!!! Lets get these things rolling!!!!! You find any extra crossover steering gear let me know!!!!
