phrogs
Registered Member
I have the Transfer case out of the truck for my transmission rebuild.
The Tcase has been leaking at the split between the two halves and at the output seal to the driveshaft.
I Started cleaning the Tcase last night and was able to remove some of the RTV that was pushed out from the two halves, it is of course very dirty at the leak origin but the case is so damn clean in that area now, I really just want to fix the leaks but If Im already pulling it apart should I rebuild it?
Now It would be my first one so I need a little help with directions on this thing so I can read over it. Any how to's? I couldn't find anything in my searchs
Does anyone know of limitations on the parts some kind of list of what to check while Im in there to verify if my parts are good or not?
I'm just not sure what to check inside this thing to make sure it is good other than the seal leaks
