My Other toy 92 Caprice Lowrider
75GmcJimmy4x4
Los Lunas NM
figured i would be a pic whore..... what you guys think
looking good outside, inside and under hood lil scary ha.. always been a fan of the B-bodies wish i had an lt1 fleetwood...
Not bad all except for that ampwire runing across your motor :eek1:
also i take it you have that sub fastened somehow. :dunno: Otherwise that trunk latch could do a number. ask me how i know :doah:
EDIT: Just noticed something else. sorry i'm so crytical. Is that a water hose in place of your heater hose??
EDIT: Just noticed something else. sorry i'm so crytical. Is that a water hose in place of your heater hose??[/quote]
its got a big 3 audio wire upgrade its actully the alt to battery wire
bolted through the bottm of the box
nope its a replacement hose i got from napa when i changed the radiator i also thought the green was wierd and i got a new one now
Damn it's just not my week :doah: I've been wrong 4 times already and 3 in just this thread :haha:
Please proceed :D
Please proceed :D
its ok to be wrong sometimes...... :haha:
my wiring is a little overkill but its needed on these kind of installs ....
and i am keeping my voltage constant at 14.7 even with audio pull :D
i have a plain jane stock 92 305 tbi . all stock and love it for dd use.
lookin to up grade the rear gears to some were in the 3.42-3.73 range. possible 350 swap later on.
well got a update on the caprice i got some 22 inch rims for it and man... what a tight fit but i can still dump it and just rubs sum inner fender.... ... well i guess im gonna go with the 20 inch rims good thing i can just swap out for cheaper..
i plan on bagging mine.
i would think twice before bagging .......... there a heavy car and you will need to have 175+ all the time in the tank just to lift .... just juice it and run a lower voltage like 36 or 48 volts 3-4 batts and you will be happier just use accumulators in the rear or it will ride like a regular low low with juice
oh, i've researched it quite a bit, bags are definately the way to go.
airbags ride far better than hydraulics, even with accumulators.
airbags can handle over 80,000lbs (think semi trucks, fully loaded) weight is not an issue.
airbag suspensions cause far less stress on chassis components, as well as much less general wear and tear on the entire vehicle.
not to mention, the an airbag suspension will just replace factory components and can be brought back to stock at any time.
i will use a system from airridetechnologies.com
i'm sure your set up is a lot of fun, i had a similar 2 pump set-up that i played with until the vehicle basically dissasembled itself. i wouldn't do hydros again, so i figured i'll try the bags this time.
well good luck with those bags a few of my club members have them and its nothing but trouble from them .... however juice installed correctly is a whole lot less issues... notice i said installed correctly ..
