which is actually the wife's, doesn't seem to be running right. It's been on my mind, but i really noticed it last night after having driven my K5 a lot recently.
It's a 91 Ford (i know, i know
) Explorer 4x2 and bone stock. V6 4.0L with the normal 4 speed auto OD transmission. Going down the freeway at 75MPH the RPMs show 3000-3500. When I shift from OD to 3rd there is no change in RPMs. The passing gear is there, b/c if i accelerate it will drop down and give me more power. if take my foot off the gas and coast the RPM will drop to the 1500 range or so in OD and then i shift to 3rd, they will jump up.
Is this normal or what? I have not done any maintenance to the trans since we have owned it which has been several years. It currently has 105000 miles as far as I know (5 digit odometer).
Thanks,
Louie
) Explorer 4x2 and bone stock. V6 4.0L with the normal 4 speed auto OD transmission. Going down the freeway at 75MPH the RPMs show 3000-3500. When I shift from OD to 3rd there is no change in RPMs. The passing gear is there, b/c if i accelerate it will drop down and give me more power. if take my foot off the gas and coast the RPM will drop to the 1500 range or so in OD and then i shift to 3rd, they will jump up.Is this normal or what? I have not done any maintenance to the trans since we have owned it which has been several years. It currently has 105000 miles as far as I know (5 digit odometer).
Thanks,
Louie
my old firebird dropped overdrive before. so im sure its the overdrive problem.
