British Slave
- Joined
- Jul 25, 2007
- Posts
- 2,086
- Reaction score
- 2
Do I need to take all the black primer a new tailgate comes painted with down to bare metal before applying green zinc?
zinc chromate is strictly for raw metal.... the black EDP coating is fine if you want to leave it. just run a sander over it thoroughly, spot in some green on any spots you sand thru, than fill prime over the whole thing...
but yes, you could strip it all off and green it, fill, yada...
what protective gear do I need? Would a charcoal filter and goggles be ok or do I need a fresh air supply? yes, disposable charcoal filters from 3M and such will be fine.. obviously an air supplied system is nice, and i used one in the collision shop, but it is not nescessary for the occasional use... as with anything, you can wear whatever protective gear you want, from goggles to gloves to a giant plastic bubble...
Do I need a HLVP gun to shoot the 2k fill primer or can I use the old style pot type gun? anything can be sprayed thru non-HVLP guns.. how do you think we did it for decades before HVLP? but you will have more overspray in the air, thus wasting a bit of product...
Can the 2k fill primer go over acrylic enamel and acrylic lacquer paints? you can, but it is not ideal... putting catalyzed products over uncatalyzed is not ideal...
You only recommended 2k fill primer in urethane right? 2k is a product line specific to Dupont.. fill primers are made by every major manufacturer...
Why is enamel garbage? because it has no hardener.. it's resin base is inferior to a catalyzed product.. it dries very soft and is far inferior in durability, etc...
Which brings me to my next point, Im figuring on just getting one of cheap HF guns. How to i prep the gun before running primer through is, and then how do i clean it when im done?
