Your rear end is whining? How do you know it’s the diff and not the wheel bearings? If you are convinced its the rear end, have you popped the dif cover off to make sure its not full of sludge?
20 miles is alot of miles with little to no lubrication on the ring. Pop the cover and take a look at the gears if they look like they have fresh wear and tear you may have done some damage. 2 litres of gear oil in teh rear is almost capacity for a corp 10 if i recall. If it took that much you may have been running dry.
I want to buy ratio 3.55 instead of what i have now 3.08. a friend said 3.08 will kill my rear end an trans because it ill nee more power to curry itself from 0.
What size tire are you running? 3.08 were stock in some blazers and trucks. Mine was. A larger than stock tire and 3.08 will/can burn the trans quicker.
I wish I could help you brother but I have very little knowledge on stuff like this. Only have the very basics. Members like Throttlechris, 4x4HIGH, TRusty, and others have far more advice and knowledge than I. I would think that a whine would be some sort of bearing starting to go out. PM one of these guys or read through the Garage forum and PM one of the guys who sound like they know their chit. I wish I could help but don't want to give you bad info. Good luck.
