The first week I started driving my blazer some onebroke off the ignition cylender and tried to steel it,
Now I do a few things every day, or do some thing one day and another the next, my truck is also has no doors or top and no wheel wells so access to battery and colum is easy /forums/images/graemlins/frown.gif
1..simply pull the power lead off the rotor cap
2. I have my ignition wire run through my dimmer switch, the dimmer is on a toggle now, so it apears to be a kill switch /forums/images/graemlins/rotfl.gif
3. fuel cut off swich, I just bought a electric pump, the switch will be along the truck on the side, as I walk by simply run my hand along the truck and hit the switch! /forums/images/graemlins/cool.gif
4. I leave my t-case in nutral and turn the tires at full lock every night, this saved it the first time, although I don't know if they got it started. Az is a flat place s I don't worry about it rolling away.
5. This is the red neck one, but a garentee... I simply pull the wiring harness off the firewall about 1/2 inch, I dont run the bolt through the middle but it has yet to ome off on it's own /forums/images/graemlins/deal.gif At night the would have no lights, ven if they could start it.
6. I just started putting a chain and a vending machine style lock I got at Home Depot. I put the fchain through a wheel and to the frame /forums/images/graemlins/thumb.gif
Last but not least I have a cheap alarm, just a 40 daller used alarm from a autozone, it won't stop a expert, but it will scare away an amature, I am going to run it through my PA, and I started the wiring for my air horn, the alarm says "help some one is stealing me!" And "back away from the car" /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif
with these things I think it should be a pain to steal /forums/images/graemlins/thumb.gif
