Admittedly this isn't on any of my Chevy trucks, but we discovered some rear brake issues on my wife's van. It's a 2014 with 70K miles and I thought it was odd the rears needed done.
I found this on 1 side
Curious if anyone else has seen this. It's some sort of build up around the outer and inner edge of the rotor that caused corresponding pad wear. You might notice where it chipped off when I banged on the rotor to pop it off the hub.
It's only on the inside. Anyone seen something like this.
The other rear side has a locked up slide pin that caused the inside pad to wear down to the metal. The outside pad still had 3/8" of pad left.
..that one was marked "defective" and sent back..I forget if it was made in China or Mexico,both those places are noted for poor quality rotors..
