Can someone point me in the right direction?
had to many problems with round 7 to 4 flat adapters and or being mia when needed . all i do now is the truck side with round 7 AND 4 flat built in to it .Another "trick" is to cut that four flat off, and wire it up for a 7 pin connector. All new rigs I've seen come with 7 pins already installed, and you can carry a four flat adapter in case you need the older stuff. Just seems more likely to need 7 pin in my book. And you've got more versatility for extra functions, if needed.
As to the adapter, be aware that the one linked MIGHT be for the older, non-weatherpack connectors. OP apepars to be dealing with weatherpack. Those trailer wiring adapters are available too. Same idea, different connectors.
