Mystery front diff
jim b
Registered Member
Long time since i was here last (probably 10 years) I'm trying to ID what I think is a corp 10 bolt but I'm not sure. The axles aren't C clip and it does have flat tops (already drilled) WK G 1 061 2 is stamped on top. Any help would be appreciated.
My guess would be it's a Dana 44.
They too have "10 bolts" on the cover and older ones (pre 76 IIRC) had factory flat top knuckles.
If possible post a pic and we can tell you 100%, at the very least just do a google image search for "GM Dana 44 front axle" to see some pics.
Front 10-bolts do not have c-clips, and not aware of any solid front axle with c-clips.
That picture is a ten bolt. The Dana diffs have different shaped covers. It's pretty obvious when you see them side by side.
No front drive axle will have c clips. They are full float by design.
