Narrow or Wide????
Do it in the road.......
  • With 2" spacers and run it real narrow
    Votes: 7 36.8%
  • Spend all my cash on 3" spacers and eat Top Ramen for a year
    Votes: 1 5.3%
  • Attach Nekidness to the hubs and run a wide load sign
    Votes: 11 57.9%
  • Total voters
    19
Again, I have 2" spacers in the rear of my blazer. Its the van 14bolt. I now wish I had the 3" spacers in the rear just to get the extra inches:crazy: . But the 2" spacers will work. You just may need to trim the inner-fender a bit if you have wide tires.
The rear is not the problem it is the front. Someone on here is running stock HMMWV wheels and 1" spacers on a SRW front 60 and rubs his pitman arm when turning but he still has push pull. I run 4.25 backspacing and by my calibrated eye 5" backspacing will clear the steering components but we have not measured anything.
Greg72 I remember your post a year or so ago aboot comparing a regular wheel to a HMMWV wheel it had some good photos.
Ira
Yeah I measured it all out a few days ago. The front will be fine with 2" spacers and if needed you could run without spacers at all in the rear.
