K10 KRAWLER
I'm in the planning stages right now on rebuilding my rig this winter, which includes tapering in the front & rear of the truck.
My first question is what do most of you guys do with your batteries?
I have a few options, but I would prefer to mount them in the engine compartment.
#1: I could run dual batteries in the box, But that would involve redoing my entire electrical system, and I HATE the idea of running an un-fused wire from the box to the starter. I could run a slave solenoid in the box, If I have to. (I have more than enough cable to do this)
#2: I like how Ryoken Did his batteries on the firewall (http://coloradok5.com/forums/showthread.php?t=194154) but would the tapered in fenders clear that setup? I also want to keep my factory heat. (I'm on a tight budget this winter and dont know if ill be able to fit a new aftermarket heater in)
#3: I would like to fit them in the front corners if it is possible at all. but I doubt I could. I was also thinking of mounting My rad in the box and putting the batteries in the very front where the rad usually sits. but will I need to buy an electric collant pump to help with the increased flow? and If I do, the cost of a pump, hose, tubing and mounting the rad back there will probably cost more than option 2 with the heater.
It seems that I have only found the negatives with this, does anyone have any good advice on doing this?
