Need 10b/d44 crossover parts (need drag link and drop pitman)
Deuling
“I like to make things”
Muskegon Michigan
4" lift going on the blazer.
Think knuckles are covered by plyr2k.
But if anybody else has anything gathering dust.... I really don't have the budget cut in to spend $500 for the ORD kit, and then also find a 2 wheel drive box... :doah:
Didn't realize my push pull steering would interfere with mounting my shocks :doah:
Parts in Colorado
I have a good set of knuckles with a new crossover arm. They are an indexed setup for added security. I can post some pictures if you are interested.
maybe just the arm and hardware?
Plyr2k is sending me the knuckles.
This arm is indexed, so you would have to mill your knuckle to match. It's a great setup, but has to be a pair.
Sorry.
Idk what the indexing means, but my buddy said he could mill and tap a knuckle for me at work no problem..
But out of curiosity what would you need for knuckle and arm... And will they fit in a flat rate?
I will post up a couple of pictures tomorrow. I am asking $150 for them and will throw in the drivers side if you want it. Let me check on a flat rate box tomorrow too.
Ok. Post the pics, and if it doesn't work out with Adam, I'll let you know.
I'd be interested in pictures if Deuling doesn't take them. D44?
Sheeeeit I could have sworn I posted up last night trying to ninja those parts, I need stuff for my planned sas. Second (or third) in line.
Here are a couple of pictures of the arm and knuckle. Not sure what that mark is in the index of the knuckle in the first pic.
I did and it looks like it will work in the larger flat rate box. Let me get a cost when I get back to work.
Well if it fits I'll take it.
It'd prolly take 2 boxes to fit the driver knuckle right?
Gimme a quote on the pass knuckle with arm only, and a quote with it all.
You have the studs and conical washers?
I got the pass. knuckle and arm in a Large Flat Rate box and it is $16.85, but it weighs in at 15lbs and the max is 20lbs. That means that the drivers knuckle will have to go separate as you thought. I could get the drivers knuckle in a Medium Flat Rate box for $12.35. I think that would be the best deal to get both.
I don't have the conical washers and bolts any more, although the bolts are still in the drivers side and they could be used.
Let me know what you think.
Well if it fits I think I'll take it.
Sounds good. Pm me a price and paypal info sir, and I'll get you my info.
Need a drop pitman. For a 4" lift 2wd style of course
Anyone have one setup for one ton tre's so both ends of the drag link are equal
