matt2matt2
Newbie
Hi, I seem to be in a bit of a bind and I need advise.
I have a 94 chevy 2500 suburban with a 454 engine. It spun a rod bearing. I already tried to replace it and drive it but that didn't work. I was told that it rounded out the block so now the block is junk. This is what I was told and it made sense. I have not measured it, but it did make sense to me that it won't hold a bearing. Now I was then told that they made changes in 94 and I can't use an older block. I don't know why not and I couldn't get a strait answer. I was then quoted $2500 for a 94+ engine. I don't have that kind of money and 94+ engines seem to be rare. I do know my way around engines and am not afraid to put one together, infact this engine is out of my truck and sitting on a pallet in my garage. So what I am asking is if what I was told is true or not? Could I use a block and crank from say the mid 80's and newer? Does it have to be a truck block?
Thanks in advance,
Matthew
Thanks in advance,
Matthew
