I'm looking for a 7/8" x 16tpi x 3/4" hiem, right hand thread I believe, need it to match a gm tre's thread. I'm trying to finish up a project so i can move it around the my buddies yard.
I was just swapping out a trashed 10bolt for a new 10bolt locker w/ flat tops, warn premium hubs and high steer x-over arms with 3/4 ton outers , but I know I want a 60 and its not even finished yet
I picked up the new 10 bolt for $150 and thought it was the deal of a century. It ha 4link brackets built over the spring perches so I totally missed the fact that the lower tie rod mounts had been removed at some point and the spring perches are and 1 1/2" too far inboard.
Well to make matters worse the high steer arms that I got were drilled for 3/4" hiem's and I have a sky drag link with 1ton tre's. Any chance this Is even made? I heard rumor that ORD had 1 but cant find it on the site.
I know the hazards of hiem's on steering and It will be done correctly when I find my 60.
Thanks[
Txchevy
. I picked up the new 10 bolt for $150 and thought it was the deal of a century. It ha 4link brackets built over the spring perches so I totally missed the fact that the lower tie rod mounts had been removed at some point and the spring perches are and 1 1/2" too far inboard.
I know the hazards of hiem's on steering and It will be done correctly when I find my 60. Thanks[
Txchevy
