British Slave
- Joined
- Jul 25, 2007
- Posts
- 2,086
- Reaction score
- 2
While cleaning up some minor issues on my engine, I discovered a bolt broken on the AC support bracket. This bolt goes thru the compressor and screws into the front part of the bracket, and the head of the bolt has female threads tapped into it. At some point the bolt that screws into the head and is one of the belt adjustment bolts was broken off. After removing the bolt, I found an easy out broken off in the bolt. Does anyone of you guys that has removed your AC have one of these bolts you would sell? I would do a junk yard, but the closet is 70 miles away.
