I need a new cam for my 350. I have the POS 290hp crate motor. I hate it. I sends half the gas out the tailpipe at idle.
No low end torque whatsoever.
Anyway... Since I'm rebuilding everything else it seems
I figured I'll use the opportunity to put in a suitable cam.
Here's the specs on the motor:
http://www.sdparts.com/product/12499529/290HP350LongBlockPreEmissionsGMCrateEngine.aspx
And here it is broken down into the individual parts:
http://paceperformance.com/index.asp?PageAction=VIEWPROD&ProdID=84482
Regardless of how it shows on the dyno chart, it doesn't perform as one would expect.
I'm running the stock Q-Jet manifold and exhaust manifolds from my old 305. I'd been running an Edelbrock 1406 (600cfm / electric choke / vac. secondaries) on there with an adapter, but I just bought a nice used Edelbrock Q-Jet to drop on there instead.
Can anyone recommend a cam that'll give me more low end torque, better idle, and better fuel economy?
Tell me about "RV" cams...
I figured I'll use the opportunity to put in a suitable cam.Here's the specs on the motor:
