Need a charcoal cannister and factory engine oil cooler to fit a 91 front
marine_enlisted
Stafford, VA
I need a charcoal cannister with mounting bracket to fit my '91 radiator support. Mine fell apart, and it stinks like fuel when sitting at stoplights.
Also need a factory "stacked plate" type engine oil cooler. Needs to have good fittings and it would be real nice if you knew it didn't leak. /forums/images/graemlins/thumb.gif
Re: Need a \'91 charcoal cannister and factory engine oil cooler
I've got the oil cooler, PM me with an offer. Lines are cut but besides that it did not leak previouslly. Do you need just the cooler or the lines and block mount too?
I had one just like that. When I tried to unscrew the lines to replace them the fittings cracked and ruined the cooler. If you can get them out without ripping the threads out or cracking the cooler I'll make you an offer. Otherwise I'll probably have 2 cracked coolers. Let me know . Thanks.
Got you, if I were to sell it I'd want to sell it all. My dad might use it in his race car so just gonna keep it.
