need a dana 60 caliper bracket. just one. pass. side
down4thakrown
flagstaff,az
what the title says, the caliper in the passenger side has play in it and moves around alittle after wheelbearings went and axle shaft broke leaving only the caliper holding wheel on....
fyi thay do make bigger wedge blocks for the normal wear on the bracket overtime.
napa sells them i know. not a comon item might take some diggin around. if i recall prem brake pads will have the paper inside that shows them offered. i might have 1 in my tool box i will look. there is 5 diffrent thicknesses of them. these will take up play on the bracket to caliper. i have used them 1 time before and thay work good.
just incase this might help you out. :thumb:
ya thats a big help! i didnt know that. i just used the needle bearings that fell out my old spindle and stuffed a few in there and siliconed each end lol.
you have to measure the gap with a feler gauge to detrmin the size wedge you need. then thay can get it for ya.
not a comon part but saves a lot of b/s . and mostly used on 2wd 1tons with the same bendix brakes. but would require a whole new spindle assembly. :doah:
