Need a few ignition part numbers
chev4life
San Jose, CA
I am having a few idle stumbling problems where I can see twiching in my tach and it only happens after the engine has completely warmed up. I think it is down to my ignition module and ignition pickup that are causing the problems because everything else is relatively new. Can you guys help me out with a few AC Delco parts numbers for these or a place I can find them? Thanks.
You can get ACDelco stuff from:
Vic Cesena & Sons Auto Elctrc
1975 Lafayette St, Santa Clara, CA 95050
Phone: (408) 982-0494
Before you start replacing the more expensive parts, take a look at some of the easier stuff like the pivot bushings on your mechanical advance weights. When these little buggers wear out the allow the advance weights to flop around on their pivot pins and WILL affect your idle and can cause stumbling as you tip off idle.
The replacement bushings are cheap (NAPA part # DP112 - less than $4.00) and they can make a world of difference.
Take a look at THIS LINK for HEI tuning tips.
Just my $.02
