need a GM 32 spline 203 and 205 transfer case
gotblazers
Vermillion,SD
If your got one to sell i'd appreciate you messaging me with 3 things
1.your location
2.What its out of and its condition (working or rebuildable core)
3.how much your looking to get
NP203
1. Oak Ridge TN
2. out of 1973 K5 Blazer
3. $100
Im pretty sure the 32 spline 203 was only made for 2 years 79-80 and available in 3/4 ton up only but if your sure its a 32 spline i'd be willing to recheck my facts.
Well you eed to recheck your fact because 203 was available before there was a 205, and it kept going till 79.
80 it was only 205 and 74 was only 203.
203 was offered behind automatics most of the years with no exception, manuals had the option some years.
:thumb:
:thumb:
Are you talking the 32 spline versions or 203s in general
Geez you should have told me I have a 203 and 205.
the 205 is out of an 81 3/4ton it was mated to a sm465
and no Idea about the 203
Right now im trying to get all the parts ready for a doubler set up with my th400 but the problem is finding a 32 spline input 203 is turning out to be near impossible. I may just go wth 27 spline 203 and 205 and toughen up my th350 if i cant find a 203 with a 32 spline input.
Just buy a new 32 spline input gear for the 203 then you don't have to worry about finding a particular case. As much as I despise telling anyone, NWF has the 32 spline input gear for $169.00. http://northwestfab.com/input.html
I was hoping someone would sell something like that but i was unable to find it. I really appreciate that link. Whats wrong with NWF or are they just overpriced?
I have 32 splined 203 that is out of a k30 dually and also have the adapter for a th 400 as far as the condition of the range box good working order would like $100 for the range box and another $60 for the adapter plus shipping what ever that cost. It is located in texas.
Thats exactly what im looking for, get me a qoute on shipping.
If its too heavy (which i suspect it will be since i can barely drag my 203 across the driveway) i wouldnt mind just taking the front gear selector box since im using it for a doubler set up anyways. Also the stock adapter will save me some driveshaft length so thatd be nice.
That is a good deal .
If i'm not mistaken in order to use the 400/203 adapter you will need to tear your trans apart and swap to the correct output shaft. Pretty sure when GM started putting the 208 behind the 400 it used a shaft with a longer stick out length.
If I were you I would grab the t-case and adapter from bigred81 regardless of shipping cost (unless of course it is waaay to expensive).
Alrite, appreciate the advice guys
:eek1:
