Need a headlight bezel
BIGCHEVYTRUCKDRIVER
The hills of Oroville,CA
Finally got my membership so what I need is either a drivers side bezel for I believe its around 77 doesnt go around the blinker or I would rather have both bezels out of a 79 which go around the blinker.
Be aware that if you change out the bezels, you will need to change out the valance under the grille. They are a different shape than what you have now and the shape differentiates the shape of the '79 bezels.
Actually this is the 79 valance and everything with the other type of bezel if you look the bottom of the bezel doesn't quite fit perfect but close enough. The right bezel for the 79 is the one that you can see was on the truck at one point look at the paint fade.
Im currently taking apart my 77, I have the front end with the bezels, but im in CO.
ive got 2 79's in San Jose.
