need a horn
jfabert
South Ogden, Utah
on my head...........no I tore down the steering column today to tighten those 4 bolts that come loose and now that it is back together the horn don’t work. I really don’t want to tear that thing down again so what is the correct to wire in the horns on the truck to a little push button I can put on the dash? I’m not very familiar with wiring, does it need a relay or can I just take the 12v straight to the button?
The problem is likely the horn cap/connection/wiring itself. Don't have to tear it down to check or fix that.
Horns are on a relay. Cheaper and cleaner to fix the existing problem.
