Need a little help with wiring up the lamps for my aftermarket gauges
Silver84k5
Hillsboro Oregon
i just bought autometer, Oil pressure and Water temp gauges..... Im in the process of wiring the lights up for them. My question is.. Do i just find the wire that is hot, when i turn the headlights on, and splice into them with the hot wires for the gauges? OR is there a more professional way of doing it? thx.
Look on your fuse panel, there should be a terminal marked inst. lamps.
I just plug into that with a male spade connector.
This is not the fuse circuit, it is a single teminal power point for the dash lights.
its only cool for lights!
We had a customer that hooked up his new stereo to the instument light "tap" in the fuse box--he couldnt figure out why it would play only at night,or with the lights on!!--it was only when I "dimmed" the lights and the radio dimmed with it(and sounded awful) that I asked him if he hooked it up to the fuse box,instead of the stock radio power wire--he said yea,there was an empty spot there,so I used that!--another guy used the same spot to power his foglights!--I'm suprised the 5 amp fuse didnt blow in either case,and the guys foglights looked like candles,even when not on the "dim" position--we rewired them with a new relay,and a toggle switch,they were 100 percent brighter!!:crazy:
That's too funny!:haha:
I only just figured out that terminal was there a couple of months ago. Sure makes wiring the added gage lights easier.:o
