I didn't have time to take the measurement before I left this morning for work, but want to prep during my break time if possible... so
I need to make a small spacer to space my transmission up from my crossmember just a bit. I have a '90 Blazer w/ the 700r4. I want to put it under the trans. between the rubber mount and the 700-241 adapter.... basically, immediately below these feet:
(this is just a stock image I found online, and not exactly the same.)
From what I understand, a measurement off of an NP208 would be fine too. Can anyone tell me the length of the bottom of the mount, as well as the distance between the bolt holes (center to center, please.) And finally, the diameter of the bolts?
I know this is kinda specific, so I don't know if anyone would be able to help via the internetz....
THANKS!!!!
I REALLY appreciate it.
