handloader90
Building!
Hey,
I have 4" Tuff Country Springs up front. I never did anything for steering correction because everything seemed fine.
I used some DIY4X EZ inches and pushed the axle 1.5" forward.
When I went to hook everything back up the drag link was too long (it took me awhile to figure out what had happened) I actually had to cut about an inch off of the threaded part of the drag link that attached to the pitman arm to get it to go in the adjustment sleeve enough to line up, and it was still a struggle getting the drag link in the pitman arm.
BTW, I'm using the stock steering arm and stock pitman arm.
I've noticed a pop/ thump sound, not really loud and it doesn't sound bad, but I can kind of feel it. I believe it happens only when I'm turning and going up a grade at the same time. For example: Pulling into my driveway which elevates.
Also, it seems like my steering radius sucks ass now, I have to do a 4-5 point turn to make it out of my parking lot at work.
I have a 2" drop pitman arm sitting in my toolbox.
Does anyone have part #'s for Moog Drag Link for our trucks?
What is your guys' recommendation for getting my steering back on track?
Also, would using one of these in conjunction with the drop pitman or drop pitman and raised steering arm work out?
