Stephen's advice is very close to what I have right now.
I don't know how wide mine is but I didn't move the seats and I have that third pedal
I was going to keep the windshield and windshield frame but that makes everything quite a bit wider and that would be the first thing to hit a rock, so I decided to ditch it and the wipers. I've run mine in the rain and a little snow, its doable. Wipers would be nice but the stock setup will be difficult to adapt unless you're using the stock windshield.
My firewall is cut pretty narrow, the fuse box mounts had to be modified and the heater box had to go.
My initial intention was to keep the stock wiring and firewall to keep things simple and to reduce the work involved, that didn't really end up being the case.
I had to rewire the truck from scratch shortly after tubing out the truck, maybe it was a fluke
I used a kit from ez wiring. As for the firewall, its support comes from the sheetmetal on the sides which I (and you will probably) cut away. This leaves the firewall flopping around, I ended up welding it to a piece of tubing that runs across the chassis.
I'll try and get some width measurements later but I'm sure they're very close to Stephen's and Fox's rigs.
Keep the rocker tube as high as you can while clearing the seats (make sure you can still comfortably get into the truck). If you add as much tubing in the door area as me (or Stephen or Fox) make sure you swap to a removable steering wheel, it makes getting into and out of the truck a million times easier. Leave at least two inches of head to tube clearance and use four or five point harnesses.
Make sure you incorporate fuel tank, cooler, tool and spare storage in your tube design.
I used a kit from ez wiring. As for the firewall, its support comes from the sheetmetal on the sides which I (and you will probably) cut away. This leaves the firewall flopping around, I ended up welding it to a piece of tubing that runs across the chassis.I'll try and get some width measurements later but I'm sure they're very close to Stephen's and Fox's rigs.
