Need advice on k5 window assy!
Timsar
Registered Member
SF / N. Kali
Hello again, my painter disassembled my two front doors, glass, vent window and the inners and just gave me a pile parts back to put together myself.
I successfully assembled everything except this last part. How do these get installed? Before the glass or after glass install?
Any tricks or special know hows?
As always, thank you in advance.
Its been a long time, but i think it needs to be in the door but not bolted in place before the glass is installed. After glass is in rollers and front track, move that rear one into place and bolt up/adjust tension.
I see. It is going to be tight in there with all the stuff and my big hand.
I believe that you should be able to work it in with the window up all of the way as you have it. It will just take some wiggling to get it to slide up the channel run felt to get into position.
You probably already have the patience from years of previous experience with the big clubs!
Thank you
Tnx
