dbreid
Hey there!
I have a 1989 V2500 (4x4 3/4 ton) Suburban. Good old fashioned 5.7L WITH Air Conditioning (which appears to maybe matter here? Pulleys seem different) and serpentine belt. I blew up the idler pulley (NOT the tensioner assembly pulley. I am talking about the stationary idler pulley which mounts on the passenger side of the engine blot (front, obviously) under the Air Conditioner.
Because I was trucking along on the highway, I didn't notice it had blown the bearing until it had spit them out and backed the bolt out. I put on a new pulley, but the Bolt itself, and the washers (on the inside and outside) and spacers took some damage, so I'd like to find a new set. No one I called has that stuff new (not like they are wear parts).
So I'd like: 1.) The bolt itself. 2.) The "concave"/Dished washer that the bolt pushes against 3.) The aluminum Spacer that goes against the block to put the pulley in the right place.
I took pictures here (images inline below).
I need shipping to 94402 and am glad to send money with PayPal/Venmo, whatever. I'll also note that there's a little rubber O-ring on the bolt that goes against the block, so I'd like to have that too. The bolt should be M12 x 1.75, btw. Please PM me if you have one you can part with.
Thanks so much!!! Dan
