need dana 44 and 14bff 4:56 or 4:88 gears
F-ingrob
Wheres the mud
san francisco ca.
looking to get some higher gears to make it a little easier on my 700R4 i currently have 4:10's and 35's but when these wear out im going to 37's and hummer bead locks
I have a set of 5.13 gears, almost brand new, for $125 shipped.
They were installed and ran for approximately 15-30 minutes and the owner decided he didn't want them anymore.
And yes, for the D44 front only. I sold the rear 14FF already.
might be interested just wondering if that is to high for 35's on the highway
my 35's are still half life
Just so you know when you said high, that should be low. When you go with a numerically higher number gear ratio its considered lower geared because it slows the spin ration. If you go with lower numerically gears, then they're considered higher gears because they spin higher.
And IMO, 5.13's would be about perfect for 37's and an overdrive tranny.
will these fit my carrier its a factory 4.10 carrier
