Need dana 60 torque specs
I feel real dumb now, found them on that page. lol
[FONT=Arial, Helvetica, sans-serif]Pinion bearing preload (new)[/FONT] [FONT=Arial, Helvetica, sans-serif]20-30[/FONT] [FONT=Arial, Helvetica, sans-serif]inch pounds[/FONT] [FONT=Arial, Helvetica, sans-serif]
Pinion bearing preload (used)
[/FONT] [FONT=Arial, Helvetica, sans-serif]8-10[/FONT] [FONT=Arial, Helvetica, sans-serif]inch pounds[/FONT] [FONT=Arial, Helvetica, sans-serif]
Pinion bearing HP60 used in rear
[/FONT] [FONT=Arial, Helvetica, sans-serif]12-20[/FONT] [FONT=Arial, Helvetica, sans-serif]inch pounds[/FONT] [FONT=Arial, Helvetica, sans-serif]
Backlash
[/FONT] [FONT=Arial, Helvetica, sans-serif]6-10[/FONT] [FONT=Arial, Helvetica, sans-serif]thousandths of an inch[/FONT] [FONT=Arial, Helvetica, sans-serif]
front wheel bearing freeplay
[/FONT] [FONT=Arial, Helvetica, sans-serif]1-10[/FONT] [FONT=Arial, Helvetica, sans-serif]thousandths of an inch[/FONT] [FONT=Arial, Helvetica, sans-serif]
Ring gear bolt torque
[/FONT] [FONT=Arial, Helvetica, sans-serif]110[/FONT] [FONT=Arial, Helvetica, sans-serif]foot lbs[/FONT]
[FONT=Arial, Helvetica, sans-serif]Bearing cap bolt torque[/FONT] [FONT=Arial, Helvetica, sans-serif]80[/FONT] [FONT=Arial, Helvetica, sans-serif]foot lbs[/FONT] [FONT=Arial, Helvetica, sans-serif]
Cover bolt torque
[/FONT] [FONT=Arial, Helvetica, sans-serif]30-40[/FONT] [FONT=Arial, Helvetica, sans-serif]foot lbs[/FONT] [FONT=Arial, Helvetica, sans-serif]
Pinion nut torque
[/FONT] [FONT=Arial, Helvetica, sans-serif]240-300[/FONT] [FONT=Arial, Helvetica, sans-serif]foot lbs[/FONT] [FONT=Arial, Helvetica, sans-serif]
Cover fill plug
[/FONT] [FONT=Arial, Helvetica, sans-serif]40[/FONT] [FONT=Arial, Helvetica, sans-serif]foot lbs[/FONT] [FONT=Arial, Helvetica, sans-serif]
Yoke U-joint bolts
[/FONT] [FONT=Arial, Helvetica, sans-serif]8-15[/FONT] [FONT=Arial, Helvetica, sans-serif]foot lbs[/FONT]
[FONT=Arial, Helvetica, sans-serif]wheel brg adjusting nut[/FONT] [FONT=Arial, Helvetica, sans-serif]50[/FONT] [FONT=Arial, Helvetica, sans-serif]foot lbs - then back off approx. 90*[/FONT] [FONT=Arial, Helvetica, sans-serif]
wheel brg locknut
[/FONT] [FONT=Arial, Helvetica, sans-serif]50-70[/FONT] [FONT=Arial, Helvetica, sans-serif]foot lbs[/FONT] [FONT=Arial, Helvetica, sans-serif]
Kingpin
[/FONT] [FONT=Arial, Helvetica, sans-serif]500-600[/FONT] [FONT=Arial, Helvetica, sans-serif]foot lbs[/FONT] [FONT=Arial, Helvetica, sans-serif]
Upper and lower kingpin cover bolts
[/FONT] [FONT=Arial, Helvetica, sans-serif]70-90[/FONT] [FONT=Arial, Helvetica, sans-serif]foot lbs[/FONT] [FONT=Arial, Helvetica, sans-serif]
Spindle nuts (the ones that hold the spindle to the knuckle.)
[/FONT] [FONT=Arial, Helvetica, sans-serif] 65[/FONT] [FONT=Arial, Helvetica, sans-serif]foot lbs[/FONT]
See? Now follow, me: Breathe.......relaaaaaaaaaax! :haha: I saw that in there but I figured it best to send the link instead of typing it out just in case it wasn't exactly what you were looking for. Sometimes we can't see what we're looking for cause we're staring dead at it, lol. Hope that helped. :D
