I'm about at the end of the rope on this truck and it's vibration. I've done just about everything I can think of and I still get a driveline vibration from 60 MPH on up. The faster I go, the more vibration I get. I need a reliable, honest shop that can put it up on a lift, run it and fix it once and for all. Engine, Tranny, Tcase, driveline or axle.
Some details and what I've done for entertainment:
2-1/2" lift (springs in front, blocks in back)
With factory driveshaft terrible vibration so dropped T-case and actually pretty good up to 75.
I wanted to get rid of the tcase drop and get it into the proper position again so saved a LOT of money to do SYE from JB Conversions. Installed kit and ordered a new TW CV driveshaft. Installed and the vibration began all over again. Checked the angles and I was about 3 degree difference. Bought a shim to bolt to spring pack the next day and now I'm 1 degree down from the driveshaft (14 degrees to 15 degrees). Still had vibration but a slight improvement.
Tried shimming 1 degree more so it was parallel with driveshaft....no change.
Rebalanced brand new driveshaft as a check, it was definitely off (from what local shop said)...they rebalanced...slight improvement.
Replaced motor mounts, replaced T-case mount (with new rubber ones)....no change.
Thinking maybe some of the bearings from the Tcase might of been worn (I used a second one to do the swap so I had 2 t-cases)....I took the whole case apart, swapped just the SYE shaft and sprocket to other Tcase, reinstalled....no change.
Took wheels off and put on jackstand. Brought to 65 and still vibration.
Rearend was rebuilt last year with new GM gears from local diff shop. Transmission was rebuilt last year as well.
Everything feels tight grabbing onto the driveshaft but it is so annoying. I thought CV shaft was the end all to any truck vibration. Now, still frustrating. Don't know if its in a bearing in the tranny, in the engine, in the tcase, in the driveshaft or in the axle.
Sorry for vent.....getting tired of taking this truck apart so many times!
