14-bolt is in place now, where a 12-bolt used to be. I have a CV driveshaft. When I had the perches moved for the swap, I had the guy tilt them so the driveshaft would supposedly point at the T-case so I wouldn't need shims like I had before. The guy acted like he'd done it many times before and knew exactly what to do.
To me it looks like a lot of angle at the pinion for this kind of setup. Best I can estimate with my little angle-ometer, the pinion is at 10 degrees, driveshaft at 25, and t-case output at 5 (all relative of course). Getting a good measure of pinion is tough. It also looks to me like I have a lot of slip yoke sticking out of the 208. It's hard to believe it could ever compress enough to use that up. If anything I expected the bigger 14-bolt to start closer than the 12 though.
What do you guys think? Should I shim it? Does the slip yoke look right for flat and level? I'd love to eliminate the slip yoke altogether and reclaim that length. Is there any easy-ish way to do that on a 208?
I really want to avoid shims to get the driveline right.
